Multicolor print
Hi!
i want to make a multicolor print whit a single extruder using prusaslicer do i use the M600 command?
https://docs.duet3d.com/User_manual/Reference/Gcodes#m600-filament-change-pause
the only probem is i dont know how it works, there is little documentation.
once i have changed the filament how i restart the print?
Or i use another method?
thx for the help! -
@Simone in my PrusaSlicer configuration I selected GCode flavor: RepRapFirmware, and it looks like in the Custom GCode section it has set Color change GCode to M600. So it may just work.
An alternative is to configure multiple tools in config.g, one for each colour, all using the same heater and extruder. In the tpost0.g file use a M291 command to ask the user "Load filament for Tool 0, press OK when done" and similarly for the other tools. Then slice the model in PrusaSlicer to use a different tool for each colour.
