Duex hadrware problem - E2-E6 outputs always ON
Hello
I have encountered a problem with a Duex board. It's connected to Duet 2 Ethernet with a tape. When I connect the power supply, all of the Duex heater outputs light on, with the last two glowing weeker. When I'm switching them by gcode, first 3 don't demonstrate any change, the last two minimally change their brightness.
My firmware version is:
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.0 or 1.01 + DueX5 FIRMWARE_DATE: 2019-12-13b1Duex PCB version is: V0.11
The issue doesn't occur after replacing the Duex board.
In a comment, I will post the config. Here I place the board's picture.
M307 H3 A-1 C-1 D-1
M307 H4 A-1 C-1 D-1
M307 H5 A-1 C-1 D-1
M307 H6 A-1 C-1 D-1
M307 H7 A-1 C-1 D-1M42 P3 S0
M42 P4 S0
M42 P5 S0
M42 P6 S0
M42 P7 S0G4 P1000
M42 P3 S1
M42 P4 S1
M42 P5 S1
M42 P6 S1
M42 P7 S1G4 P1000
M42 P3 S0
M42 P4 S0
M42 P5 S0
M42 P6 S0
M42 P7 S0G4 P1000
M42 P3 S1
M42 P4 S1
M42 P5 S1
M42 P6 S1
M42 P7 S1 -
When and where did you purchase the Duex?
Can you test the outputs with a multimeter to see if a voltage is present when the heaters are turned off?
I have tested it. On first 3, there is constant 24V on their pair of pins, not even light changes when i switch them. On the other two, voltage switches between 4-15 or 2-9 V, so when they are turned off their voltage never drops to zero.
Purchase date: 25.05.2023, INV-1986
@developerOI if you have swapped out the Duex5 and that one works then please contact warranty@duet3d.com
I see you bought this directly from Duet3D.
