Error: M950: exactly one of FHJPSR must be given
Board: Duet 3 Mini 5+ (Mini5plus)
DSF Version: 3.4.6
Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.6 (2023-07-21)
Here is my config file.Can you please assist? config (2).g
@amjm22 When opening your config.g in a browser, it is an unreadable string. In the forum editor, you can use the "</>" tag to create a box to which you then can paste the config like this:
; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3+2 on Wed Mar 20 2024 06:10:00 GMT-0400 (Eastern Daylight Time) ; General M550 P"TheMachine" ; set hostname ; Network M586 P0 S1 ; configure HTTP M586 P1 S1 ; configure FTP M586 P2 S1 ; configure Telnet ; LED Strips M950 E0 C"io1.out" T1 ; configure LED strip #0 ; Smart Drivers M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis) M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1 Z0.2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z800 ; set axis driver currents M92 X80 Y80 Z80 ; configure steps per mm M566 X1200 Y1200 Z1200 ; set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 ; set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 ; set accelerations (mm/s^2) ; Extruders M584 E0.3 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E700 ; set extruder driver currents M92 E690 ; configure steps per mm M566 E1800 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E1000 ; set accelerations (mm/s^2) ; Kinematics M665 R150 L360.24 B140 H520 ; set delta radius, diagonal rod length, printable radius and homed height M208 Z0 S1 ; set minimum Z M666 X0 Y0 Z0 A0 B0 ; endstop adjustments and XY tilt, can be determined using auto calibration as well ; Probes M558 K0 P5 C"nil+io4.out" H5 F120 T6000 ; configure digital probe via slot #0 M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Endstops M574 X2 P"io3.in" S1 ; configure X axis endstop M574 Y2 P"io5.in" S1 ; configure Y axis endstop M574 Z2 P"io6.in" S1 ; configure Z axis endstop ; Mesh Bed Compensation M557 R135 S40:40 ; define grid for mesh bed compensation ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 C7.06e-8; configure sensor 0 as thermistor on pin temp1 M950 H0 C"out0" T0 ; create bed heater output on out1 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S145 ; set temperature limit for heater 0 to 145C M308 S1 P"temp1" Y"thermistor" T100000 B4725 6e-8 ; configure sensor #0 M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 ; configure sensor 1 as thermistor on pin temp2 M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out6" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"out5" ; create fan #1 M106 P1 S0 B0.1 H1 T45 ; configure fan #1 ; Tools M563 P0 D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ; Miscellaneous T0 ; select first tool
The error message hints at some wrong port assignment with
M950
, in this case, I think you assign IO_1 twice:M950 E0 C"io1.out" T1 ; configure LED strip #0
BTW, in both cases, the comment is misleading, it doesn't match the effective IO-ports
@amjm22 M950 with E parameter to support LED strips is only available in firmware 3.5.
@amjm22 In RRF 3.4.6, you can only connect LEDs to the 4-pin connector labelled DS_LED. Configure with M150. See this page for details: https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_Neopixel_DotStar
Thank you so much! you guys ROCK
