Duet 6 HC and 3HC Board Not able to Integrate with WELDER
Hi Everyone,
I have built a Custom CNC using 6HC mainboard and a 3HC Expansion board. Integrated with a welding machine controlling through a 5V normal relay. During the tryouts without the weld machine ON is good i.e., that is the torch movement.
However when tried integrating the WELDER with the CNC the X and Y Axis doesnt move only the welder switches ON.
And observed that the X and Y Axis stepper motors are able to rotate by hand. I am suspecting some kind EMF Interference.
Requesting the help of Forum members on understading and solve this issue
@SANJR please supply a link to the technical data for the welder and explain how you have connected it to the Duet.
