Arc moves on XV plane
i have kind of an IDEY Kinematics two idependent Y axes (Y and V) are moved together by one X.
Of course arc move with XY works, but i want to switch to XV, without changing HW and less config changes.
I saw G17/G18/G19 but do not seem to match. Is there another solution?Thanks and best regards
wiego -
@wiego wouldn't you define multiple tools (XY / XV (XVU for mirror/ copy mode), and then select the tool for your print and the arc motions would be applied correctly afterwards?
@wiego There's no command like G17/18/19 that lets you map XY arcs to arbitrary axes. However it is possible, but not without some small configuration changes, by using the axis mapping function of M563.
See my reply here: https://forum.duet3d.com/post/330290Ian
@wiego if you map Y to V on a tool and select that tool, then arcs that would normally be XY will be XV instead.
