Configuring Pre-Stall
@jjem you are right, currently M220 isn't applied to moves in macros at all. I'll look at how easily this can be fixed.
@jjem this should be fixed in the firmware I have just uploaded to https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
@dc42 Great, thank you
@dc42 No luck unfortunately, I updated mainboard and all expansions but behaviour is the same.
@jjem I've just tested that macro, and with the new firmware build it works correctly for me when I invoke it directly from DWC.
@dc42 I have tried updating again, in-case I had the wrong files, but still not luck. I can't see a DWC update file, do I need one? It's currently on 3.5.0-rc.2 whereas all other boards are now on 3.5.0-rc.3+
@jjem Do you mean your mainboard isn't updated? I think you're on a 6XD. Use Duet3Firmware_6XD.bin from @dc42's dropbox link above. It's there, I've checked!
For DWC, use "DuetWebControl-SD.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-rc.3Ian
@jjem please post the output from sending M115 or M122, to confirm the firmware version you are using.
I tested the behaviour when running a macro directly from the Macros menu in DWC. It is likely to behave differently if the macro is called from a system macro such as pause.g.
@dc42 M122 returns
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.5.0-rc.3+ (2024-02-26 21:13:26) running on Duet 3 MB6XD v1.01 or later (standalone mode)
And the settings show this:
I've updated DWC to 3.5.0-rc.3 but that hasn't helped.
thank you. Do you know when that might be ready, so I can plan around it? Thanks.
