Non standard application
Hello all,
I am building a custom device that uses 6 stepper motors with homing switches on each. This is not a printer or cutter, no defined 'axes', just specific motors that I need to coordinate the motion of. Would it be possible to use the Duet 3 6HC (I have one on-hand from a 3D printer I was working on). I like the idea of using G Code to program all the motor motion but can't use a normal coordinate system. Any thoughts?
Thank you
@Johnnyg yes you can do that, just use the default Cartesian kinematics and treat each motor as if it is an axis.
