Unsolved Duex 5 Hardware - SMD component specifications
i need the some information about 2 SMD componebts mounted on the DueX 5 Board.In more detail do i need the manufacturer, model and the parameters / specifications from the diodes D7 and D18, listed in the BOM as
- "DB2W40300L", "D_SOD-123F"
and - "DO-219AB", "DO-219AB"
of the Duet3D DueX 5.
Are there any replacement variants for these components, if the original parts are not available to order or too expensive?
Thank you in advance..
@wildblue DB2W40300L is a part number so you can look it up, basically a 3A 40V Schottky diode. D18 is a 1A fast recovery silicon diode rated 40V or greater.
