Does anyone use the M670 command and G1 P parameter?
I am looking at changing the way M670 works so as to make it easier to implement over CAN. The change would be that M670 would no longer take a list of pin names in the C parameter. Instead the P parameter would be restored and this would be a list of GpOut port numbers that have been assigned using M950.
Is there anyone out there who would be adversely impacted by this change?
FYI for those like myself who don’t have every G and M code memorized:
https://docs.duet3d.com/User_manual/Reference/Gcodes/M670
M670: Set IO port bit mapping
Parameters
Pnn:nn:nn... - List of logical port numbers that bits 0, 1, 2... control (supported in RRF2.x and earlier)
Cnnn - Used to specify the pin name(s) to be controlled (supported in RRF3 and later, see Pin Names)
Tnnn - Port switching time advance in milliseconds
