[3.5rc1] 12864 menu issues and multi-stream gcode issues
I recently updated 2 of my printers to 3.5rc1 yesterday, one of them came from 3.4.5, the other from 3.5b4:
On both printers, my
actions
file in my menu system no longer function properly, none of the M98 lines execute the macro (https://github.com/pfn/voron2-rrf-config/blob/master/menu/actions). I think I also tried verifying the filelist macros and those didn't work for me, but others on discord were unable to repro.Additionally, a problem similar to one I previously had in 3.5b2 has re-surfaced (https://forum.duet3d.com/topic/31812/3-5b2-macros-called-from-a-job-lose-parameters). When I use my
job-prologue.g
as start gcode in my print job, as soon as the heat-wait loop completes, execution jumps ahead toclean-nozzle.g
which causes an abort due to either homing not yet being completed, or the print head temperature not being up-to-temp. The abort occurs immediately, but the job-prologue.g continues executing to completion, so the printer then proceeds to home and then set/wait for the nozzle to reach temperature.Aforementioned files for reference:
- https://github.com/pfn/voron2-rrf-config/blob/master/sys/job-prologue.g
- https://github.com/pfn/voron2-rrf-config/blob/master/sys/k/clean-nozzle.g
I also encountered a problem with canceling a job, I don't recall the exact repro steps, but it is similar to what I previously described in https://forum.duet3d.com/topic/32937/3-5b4-dwc-stops-responding-after-canceling-a-job-on-12864 -- I think I canceled a job on DWC, and thereafter, the printer would not respond to any commands at the 12864 or vice versa.
It seems the 12864 menu issue is https://github.com/Duet3D/RepRapFirmware/issues/909 I guess we'll see this fixed in rc2? And then I can quote/escape the line to
"M98 P""#0""" L"..."
? I suppose I could also make the argument embedded in the M98 line...Going by that, I would expect my
macros
menu file to be similarly non-functional as that is simply written as"M98 P#0"
(https://github.com/pfn/voron2-rrf-config/blob/master/menu/macros) -
@pfn there are 3.5.0-rc.1+ firmware builds available at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0 which include the fix for this.
@gloomyandy yes I think it does - AFAIR Christian implemented a fix to cause both channels to wait for temperature.
