G32 Error: Probe was not triggered during probing move
Less than 10mm form bed
@mcadbob said in G32 Error: Probe was not triggered during probing move:
Have you been able to do just a plain G30 and have the probe work?
Yes in homeall it works fine
In your first post you mention that the bed stops about 10mm away from the bed.
Given the dive height and trigger height settings of your probe I'm not really surprised.
Since the printer is fully homed before doing a G32, try adding a command to move to Z=10 at the start of the bed.g file.
Let us know.
After the G23 S2 I put G1 Z0 F100 the bed move to zero then it move to 11.75 Z and moved to the first P0 point.
how did it get Z11.75? -
What is a G32 S2?
At the start of a probe the position on the Z axis is set at the probe Z Trigger Height (in your case 6.75) plus the Dive Height (in your case 5), thus the 11.75.
But the firmware should have no problem probing from that Z position unless something is preventing the probe from getting to the Z position where it triggers.
I mistype G29 S2
Ok I see the 11.75 now
it works with G30 but not G30 P0 X20 Y20 Z-9999 -
I took the 6.75 to 0 and the H5 to H3 and it trigger but
Error: Some computed corrections exceed configured limit of 1.00mm: -1.892 -2.778 -2.358 -2.208
Can I set the range to a larger number -
You need to add the S parameter to your M671 command to give it a tolerance for adjustment.
Thank you for you Help. I will try that tomorrow
I still do not see that it has to be that close to work? -
You cannot just set the Z Trigger Height parameter to any value. It has to be the actual height above the bed that the probe triggers.
I think you have an inductive probe and it's trigger height might be in the range 2mm to 4mm.
Did you calibrate the probe to determine the Z Trigger Height parameter as accurate as possible?
