Duet conversion
So, I've used the duet on a few (5 or 6) printers for several years, but it's been a while since I was in the nitty gritty of setting one up. I inherited an old delta and switched all the wiring over from the MKS setup. I can access the web portal and home the printer, but I cannot move the printhead. Any ideas on what might be going on here? Endstops seem to be correct, as it homes and the LED's light up upon homing.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Jul 10 2023 14:44:47 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"LargeDelta" ; set printer name
M665 R325 L247 B150 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
; M551 P"tigger1968" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X350 Y350 Z350 E650 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 R85 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
@Legrand said in Duet conversion:
M208 Z0 S1 ; set minimum ZMost of the axis limits are missing......
@Legrand almost certainly it’s your endstops:
Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
Your endstops are at the top, ie the maximum end of the axes, and you home to the top, so they should be X2 Y2 and Z2.
@DIY-O-Sphere that’s normal for a delta. The XY limit is defined as a circle, the radius of which is the B parameter in M665. So you only need Z in M208.
A delta radius of 325 seems unlikely, it is generally only a bit bigger than the B value, and smaller than the L value. You probably have diameter rather than radius, so halve it. See my post here for guidance on setting these parameters: https://forum.duet3d.com/post/289874
@droftarts said in Duet conversion:
Sorry, I missed that.....
Changed to X2, Y2, Z2, LED's now illuminate when away from end stops, printer homes, but still cannot move axis.
@Legrand Are you getting any error messages in the console? Generally you need to move down in Z first with a delta, you can't move X and Y at the top. The area you can move in is like a cone on top of a cylinder, because the axes would have to move past the homing point (and axis limit) to move in X and Y at the limit of Z.
@droftarts Got it. It was the delta radius issue. I didn't think that would prevent the move, but, apparently it did. Thanks.
Movement cannot be computed if the rod length is less than the delta radius.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
