Duet3D is useless as a CNC Controller!
@Atair said in Duet3D is useless as a CNC Controller!:
s for the GCode - i went with the default-ish Mach3 postprocessor (using RhinoCam / VisualMill), and there the arcs got messed up (the two 'lower' ones - out of 4 total).
I think this may be the cause of the issues you are having. A Mach3 postprocessor will not produce g-code that works well with RepRap firmware.
and one additional suggestion - why no option to parse the code? check for soft limits etc. I can only upload it and then run it - any syntax or user errors show only when i am already cutting.. As the preview in my - 1-2 year old version - cant give me any indication of problems..
So even with an update to the latest firmware etc. - i think an option for a sanity check would be in order - which in turn would need a separate method besides run. 'Parse File' maybe?
@Atair there is the option to simulate a job.
@T3P3Tony Thanks, found all i need after a firmware update (3.5.0 RC). The GCode viewer is a bit erratic, but it works.
What are good value ranges for the M669 Snnn Segments per second? I have it at 10 for now, it works, but still a little laggy. -
@Atair a value of 1 for S and T is fine
@Atair Sorry I am late to this, been a bit under the weather the past few days. When visualizing g-code for CNC Routers etc. I recommend setting the following settings.
Force line rendering (Make sure quality is not set to max)
Render G1 - Early on I ran into some cases where slicers were use G1 for everything including travels for 3d printers. I added this flag to help address G0/G1. Though I think with Fusion 360's changes they force all moves to G1 on their hobbyist versions so depending on what you use to generate g-code there could still be render issues.
With those settings you should have a better view of the toolpathing. Here is a sample of some drag knife tool pathing
What is it that you find laggy: the response to a pause command, or something else?
At low speeds the T parameter (minimum segment length) matters too. In your example with S=10 and assuming the default T=0.2mm, if the speed is 2mm/sec or greater then the S parameter will define the segment time (0.1sec); but if the speed is lower than 2mm/sec then the T parameter will define the segment length. For example, at 1mm/sec the segments will be 0.2mm long and will take 0.2sec each. If you want to maintain 0.1sec response time to a pause command then you would need to reduce T to 0.1mm.
@dc42 i see, both parameters are relevant, my question was more in the direction of performance limits. (I am mostly interested in live feed rate adjustments)
Now with S10 it works, although i had two instances of gcode lines being interpreted wrong. I could not reproduce it, but both times it happend, the tooldhead was under load.
It was not lost steps, but the head moving to a totally wrong position.. Could be of course something different, but could also be data corruption.
Edit: and both times it was on the last segment of the gcode.. maybe there is something after all.. If i find out more i will post it. -
@dc42 ok i just ran another job.. and this time it did not fail, but also did not finish. main3.gcode
it just does not do the last line - a simple z axis move, and instead just stays there. i have to manually cancel it, and then reboot the controller.I assume it is because of the S10? or some other thing with the current RC version?
using Duet Web Control 3.5.0-rc.1
thanks -
@dc42 ran the same code a second time, this time on the start of the last segment:
Line 423: G1 X263.075 Y-0.997 Z-7.000 F300.0
it never started this line, instead went diagonally towards zero i guess.. so happend 3x in a row - i was lucky that it is plywood and it did not break anything important, but there seems to be a real problem with this latest RC..
It never reached the last line, Line 424: G1 X263.075 Y-0.997 Z10.000 F1200.0, (the Z-Lift)I also have a second job, here: 4Holes.gcode It runs before the main cut, and never has any problems. I guess the lines are too short to have any effect with the segmentation.
Here my config.g in case that helps (there is also the M669 S10 command)
config.g
