Congig.g and bed.g files modified program confirmation
Greetings,
I have recently added Duet 3D Expansion Board 3 HC to my Duet 3D Main Board 6 HC. And have made changes to the config.g and bed.g files. Request the Input of members to check for any corrections, improvements or suggestions
Config.g file
G4 S2 ; wait for expansion boards to start
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M569 P1.0 S0 ; physical drive 1.0 goes backwards
M569 P1.1 S0 ; physical drive 1.1 goes backwards
M569 P1.2 S0 ; physical drive 1.2 goes backwards
M584 X1.0 Y1.1:1.2 Z0.0:0.1:0.2:0.3 ; set drive mapping, Z Motors dr 0(front left),dr 1(rear left),dr 2(rear right),dr 3(front right)
M671 X5:5:545:545 Y70:455:455:70 S5.0 ; leadscrews at Front left, Rear Left, Rear Right and Front right
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X400.00 Y400.00 Z400.00 ; set steps per mm
M566 X300.00 Y300.00 Z180.00 ; set maximum instantaneous speed changes (mm/min)
M203 X3000.00 Y3000.00 Z600.00 ; set maximum speeds (mm/min)
M201 X100.00 Y100.00 Z20.00 ; set accelerations (mm/s^2)
M906 X2520 Y2520 Z2520 I100 ; set motor currents (mA) and motor idle factor in per cent
M84 S3600 ; Set idle timeout; Endstops
M574 X1 S1 P"!1.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in via CAN address 1
M574 Y1 S1 P"!1.io1.in+!1.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y1 & Y2 via pin io1.in & io2.in via CAN address 1
M574 Z2 S1 P"!io0.in+!io1.in+!io2.in+!io3.in" ; configure switch-type (e.g. microswitch) endstop for High end on Z via pin io0.in,io1.in,io2.in,io3.in in the Main Board; bed.g
G28 ; home
G90 ; set to absolute positioning
G30 P0 X5 Y70 Z-1.0 ; probe near a leadscrew
G30 P1 X5 Y455 Z-1.0 ; probe near a leadscrew
G30 P2 X545 Y455 Z-1.0 ; probe near a leadscrew
G30 P3 X545 Y70 Z-1.0 S4 ; probe near a leadscrew and calibrate 4 motors
M400 ; wait for current moves to finish -
@SANJR your configuration file looks plausible to me, except that 400 steps/mm for X and Y would be unusual unless those axes are driven by leadscrews or ball screws. You have not declared any extruder drives, so I guess it is a CNC machine.
I don't see any M558 command to configure the Z probe.
@dc42 Thanks for the feedback
Yes, M8 lead screws are being used for the axes, and the machine is planned for CNC purposes.
Heregoes the M558 command
M558 P5 C"!io8.in" H30 F300 T6000 ; enable Z probe sensor endstop io8.in (Main Board) set dive height, probe speed and travel speed
G31 X0 Y0 Z15.0 ; set or report current probe status
M557 X0:550 Y70:460 S100 ; define mesh grid
