Error: This kinematics does not support auto-calibration
Hi All.
I’m rebuilding my printer and have upgraded to RRF3
I'm using a Duet 2 Ethernet controller and M122 reports
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet Ethernet 1.02 or laterI’ve started with new configuration and supporting .g files.
I’m trying to get my BL-Touch sensor to work and I’m running into a problem.
In Config.g I have...
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger heightM557 is commented out
HomeAll.g just contains the movement commands to set the home position
Both Deployprobe.g and Retractprobe.g work as expected.
G30 S-1 works and reports the current positionHOWEVER,
G30 S0 works, sets the z height to 7.5 then reports...
“Error: This kinematics does not support auto-calibration”Anyone have any idea what’s triggering the error?
Best
DerekJ -
@DekJak try using just G30 without the S0.
Many thanks for the very quick reply.
G30 without S0 works perfectly,Cheers
DerekJ -
@DekJak thanks. I've created https://github.com/Duet3D/RepRapFirmware/issues/910 to track this.
