Part Cooling Fan Setup
I am trying to setup up a fan for part cooling during printing after the first layer is complete. I am using a 5v blower fan in the fan 0 port. Ive plugged it into the 5v always on port to make sure it works.
When i go to test the fan on the dashboard and turn it on nothing happens did i set it up correctly?
here is my config:
; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H0 S260 ; set temperature limit for heater 0 to 260C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H0 F0 S"Main" ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Which Duet board?
Can you send M122 and M98 P"config.g" in the gcode console and copy and paste the results here? That will give some additional information.
If it's a 5v fan, how are you providing power to the fan ports? By default they would match VIN.
@Drak said in Part Cooling Fan Setup:
What exactly do you mean by this?
Does the fan work if you send
M106 P0 S1
M122 results:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DGM-956GU-DJMSN-6JKF0-3SJ6T-KBNRD Used output buffers: 3 of 26 (12 max) === RTOS === Static ram: 23860 Dynamic ram: 75300 of which 0 recycled Never used RAM 12920, free system stack 184 words Tasks: NETWORK(ready,12.4%,235) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,86.0%,416) IDLE(ready,1.6%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:49 ago, cause: software Last software reset at 2023-09-27 22:48, reason: User, GCodes spinning, available RAM 12920, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.7, current 33.9, max 34.3 Supply voltage: min 12.2, current 12.2, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: standstill, SG min n/a Driver 6: standstill, SG min n/a Driver 7: standstill, SG min n/a Driver 8: standstill, SG min n/a Driver 9: standstill, SG min n/a Driver 10: Driver 11: Date/time: 1970-01-01 00:00:00 Cache data hit count 1702803860 Slowest loop: 23.56ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.1ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === DueX === Read count 1, 1.21 reads/min
M98 results:
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Heater 1 not found
Error: Heater 2 not found
Error: Heater 4 not found
Error: Heater 5 not found
Error: Heater 6 not found
Error: Heater 7 not found@Phaedrux said in Part Cooling Fan Setup:
Which Duet board?
Duet wifi 2 and Duex 5
I meant that i tried moving the fan slider bar on the dashboard and nothing happens
M106 P0 S1
?No nothing happens, when i plug the fan into always on 5v it turns on though.
picture of jumpers and fan connector on board....
If it won't come on with a manual command then either the wiring is incorrect, or the fan mosfet for that header is damaged.
Do you have a different fan to test on that header?
@Phaedrux the fans came in a set of 4 so i tried another and had the same result. Should i try it on one of the duex 5 fan headers?
yes trying a different header would be a good next step.
@Phaedrux I tried connecting to the fan port 3 on the duex 5 board but i get this error when i run the m106 command
On my dashboard no fans appear:
here is my config
M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M575 P1 B57600 S1 ; Drives M584 X4 Y1:2 Z9:8 E0 ; set drive mapping M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes FORwards M569 P3 S0 ; physical drive 3 goes forwards M569 P5 S0 M569 P6 S0 ; physical drive 3 goes forwards M569 P7 S0 ; physical drive 3 goes forwards M569 P8 S1 ; physical drive 3 goes forwards M569 P9 S1 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X816.5 Y793.4 Z626.4 E100.00 ; set steps per mm M566 X500.00 Y500.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X600.00 Y600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X25.00 Y25.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X260 Y300 Z350 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop+!e0stop" ; configure active-high endstops for low end on Z via pins zstop and e1stop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P5 C"^zprobe.in" H5 F120 T3000 G31 X20 Y0 Z3 P25 M557 X15:250 Y15:300 S50 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H0 S260 ; set temperature limit for heater 0 to 260C ; Fans M950 F3 C"fan3" Q200 ; create fan 0 on pin fan0 and set its frequency M106 P3 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H0 F3 S"Main" ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
M950 F0 C"fan3" Q200 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M563 P0 D0 H0 F0 S"Main"Try this better
