No Load filament option when using two extruders on a tool
Hi guys,
I think this might be a bug. it would be good if you move the topic to appropriate section if needed.
so the situation is that I am using 2 extruders for a single tool - push/pull setup to make long distance easier for the extruder.when the tool is setup as follows:
M563 P0 S"Left Extruder" D0:1 H1 F3There is not option to load the filament into the tool. Trying to load the filament manually the following message appears
M701 S"Aurarum PVC"
Error: M701: Loading filament into the selected tool is not supported -
