Nema 34 duet 6
Hi all ,
Did you think with the new duet 6hc 6.3amp i can drive those motor in 24 v? https://www.soprolec.com/shop/fr/moteurs-pas-a-pas/255-pas-a-pas-nema-34-35nm-86cm35.html
ithx all
@Amagatth yes, no problem running those
@jay_s_uk with full trothle you think ?
@Amagatth yes
@Amagatth yes you can drive them from the 6HC, but use the calculator at https://www.reprapfirmware.org/emf.html to estimate the maximum speed you will be able to use before they start to lose torque at 24V. If you want more speed than that, you should use 48V power.
@dc42 i check with my speed (1000mm/s-1200mm/s) i need 23.3v to have full torque
