Loaded filament custom settings
Hi all,
got a question.
I have setup few different filaments and the config.g contains only retraction and pressure advance settings.
when performing load filament operation everthing works fine.
The issue is that after restarting the printer the loaded filament remain on the screen as it would be loaded (the filament that was used prior to the shutdown), but the settings haven't been loaded.
i.e. it has retaction of 2mm that I have no idea where it is coming from. I don't have this setting anywhere.
the questions is how to make it load the last used filament that is actually displayed under the tool.thanks in advance
undefined Phaedrux marked this topic as a question
@Aurimas You should put
M703
in your tpost*.g. If there is a filament assigned to your tool and you select it, that will execute the filament's config.g automatically. -
@chrishamm thanks - it looks like it works fine. thank you
undefined chrishamm has marked this topic as solved
