Change feed rate during Z homing
Not sure what title to use but essentially I was wondering if there were any way to replicate the feed rate change behaviour that I seem to recall happened with DCs IR probe (although it's been an awfully long time since I used one so I might be mistaken). The use case is this - I normally use the nozzle as a Z=0 switch. But because I have about 600mm travel in Z, I do an initial fast move to get somewhere close (about 40mm or so), then home Z at "normal" speeds. For this new build, I've installed a slotted optical switch. So the plan is, at the start of home Z use M574 to map the optical switch, do the normal G1 Znn H1 at a high feed rate then send another M574 to revert to the "nozzle switch" and home in the normal way at slower feed rates.
Although this should work, it would be more elegant if the feed rate changed within a single homing move (i.e. when the first optical switch triggers) which is how I recall DC's probe worked. Is there any way of doing that? If not, is there enough other interest to ask for this to be added to the firmware wish list?
@deckingman why not configure the two sensors as separate Z probes? Then you will be able to specify different F parameters in their M558 commands. Use the K parameter on M558, G31 and G30 commands to specify which probe to use.
@dc42 said in Change feed rate during Z homing:
Ah, well that would be historic. It stems from when expansion boards were first introduced and probes were not initially supported. Ever since then I've always defined the "nozzle-as-probe" as a simple switch and used G1 Znn H1 rather than G30.
Sure but that still involves two separate moves at different feed rates does it not? I was asking about one fluid move with a feed rate change after (or rather while) the first end stop triggers or is triggered. i.e. the Z move commences at a fast feed rate, continues at that feed rate until the first (optical) switch triggers, then finishes that same move at a lower feed rate.
For info, the mechanical flag which interrupts the optical switch is positioned such that it will trigger about 40mm before the nozzle touches the bed and remains triggered up to and beyond Z=0. This is to ensure that a fast move won't happen if the nozzle is less than 40mm from the bed.
I'm not sure if it would work but if you play with segmentation maybe you can set your proximity sensor up on a trigger to reduce the max Z speed ?
Alternatively, if you just send two G30 moves sequentially, there really shouldn't be any discernible delay between the two.
Just set the first to do a single probe and single high speed.
Maybe wrap a conditional to check it's not already triggered. -
This post is deleted! -
My arrangement is similar, I use a simple switch to ensure Z being around 30 mm above the bed. That happens once when I power-up my printer (usually during homeall.g) and is almost unnoticeable within all the X and Y moves. After that, I redefine my (opto-mechanical) probe to take the part of the Z switch (just as @dc42 proposes in his above post). So, all subsequent homez.g calls just run the "second half" of the sequence, I.e. a precise homing at the center of the bed.
It is an intriguing idea to smoothen the Z speed while it travels from an unknown position to a switch and then forth to the final probing position, but in practice, the initial move to the Z switch is only needed once to establish a coordinate system. All subsequent homing moves operate from a known position in space and just use the Z probe.
Just for info, I used to have a second micro switch on a sort of swinging arm arrangement, so I'm used to doing a fast home to the first switch, followed by a second home at lower speed to the second switch. Actually that's not quite true because I stupidly forgot that I could home to the first switch and instead had it set as a trigger. So I used to do a fast 100mm move, check the trigger, and repeat as necessary. But whatever....
The older I get, the more my memory fails me but IIRC, DC's IR probe (being an analogue device) used to slow down the feed rate when the output reached a certain level (proximity to the bed). So if I'm right and my memory isn't playing tricks, then the firmware used to exist. So I was just wondering if that behaviour could be reinstated or replicated with the caveat being that the the feed rate change would happen when a second switch triggered rather than when an analogue input reaches a threshold value.
I'm reluctant to do the high speed homing straight to the "nozzle as probe " switch in case that switch should fail. Being a heavy lead screw driven bed, I can only drive it at high speed using high motor current, so bad things would happen. By having a second switch, then both switches would need to fail for a high speed homing move to cause extensive and expensive damage.
But it's no big deal and two separate homing moves will work well enough - it was just a thought......
@deckingman said in Change feed rate during Z homing:
Well the docs for the sensor indicate that behaviour.
Doesn't prove you're not losing your marbles, but you should be able to find your keys 🤪Always use a P value of 500. When the probe is triggered, the Z probe reading will be about 535. When it is slightly higher than the trigger height, the reading will be about 465. With a P value of 500, when the Duet sees the reading of about 465, it knows it is getting close to target height and it will slow down the Z motor.
What's wrong with using two separate moves? First a G1 H1 move using the optical switch as the endstop; then configure the nozzle switch to be the endstop instead and use a second G1 H1 move at a lower speed. The only difference is that the Z axis will stop when the first move finishes; but if the second move is at a slow speed, the stop may not be noticeable anyway.
...........There is nothing wrong with it all. But as I mentioned in my very first post which you don't seem to gave have bothered reading, I simply asked if it would be possible to replicate the behaviour of the IR probe, as that seems to be quite an elegant solution.
A simple "no it isn't possible" would have sufficed.
If I'd known that such a simple question would lead to an argument, I wouldn't have bothered asking the question.
Sorry to re-visit this topic which seemed to cause such a furore, but I've started to commission my new printer and have additional data.
Homing moves to a switch, of necessity cannot have a deceleration phase. So the answer to the question "what is wrong with using two separate moves" is that when one has a large heavy bed weighing several Kgs, an instantaneous stop from even a modest speed such as 20mm/sec, results in a violent jerk which can cause belts to jump, thus destroying any bed levelling that might have been done, and in the longer term is likely to cause irreparable damage to both the lead screws and their nuts.
In the short term, I'll revert back to the original method of using the first end stop as a trigger and using a conditional loop to do a series of fast 100mm or so moves, and checking the trigger state after each iteration. This does involve even more moves, but at least each one begins and ends with an acceleration and a deceleration phase, thus preventing the violent and "damage causing" sudden stop.
In the longer term, and when funds allow, I might buy an IR probe and position this somewhere/somehow so that I can use this as the first end stop. This will/might give me the feed rate change that I was tentatively enquiring about in my opening post.
This is already logged as a requested enhancement on github, https://github.com/Duet3D/RepRapFirmware/issues/746.
That sounds a good solution to me.
I'm sorry, support for changing the feed rate during probing when using a probe with analog output was removed several versions ago. It was replaced with the ability to configure repeated Z probing using a faster feed rate the first time. I appreciate that this doesn't solve your issue.
@dc42 To be clear on the use case for this, I like to do all homing at reduced motor currents so that if a switch fails, the motor will stall before too much damage occurs. This is especially true in my case whereby I use the nozzle tip as the switch/probe with only about 5mm of movement in the kinetic mount. The hot end is a Slice Engineering Mosquito so too much upward pressure on the nozzle would cause extensive (and expensive) damage to the extremely thin walled heat breaks.
A realistic initial homing move for a screw driven heavy bed at reduced motor currents is about 300mm/minute (5mm/sec) and I follow this up with a fine homing move at 60mm/minute (1 mm/sec).
But I have about 600mm of vertical travel in the Z direction so if I had previously printed something that tall, it would subsequently take 2 minutes (600mm at 300mm/minute) just to do the initial Z homing. Hence the need/desire to do a much faster move, at full motor current, to get the bed somewhere close to the print head prior to homing proper.
The new slotted optical switch is more elegant than the older micro-switch on a swinging arm arrangement that I had before. I have now reverted back to the old way of doing things (a series of fast 80mm moves checking the status of the trigger at each iteration) and it is working well but the ability to change feed rate at a trigger point somewhere during one continuous move would be even more elegant.
I nearly created a thread to ask for a solution like @deckingman and your post made me really happy!I applied this method to my routine but it doesn't work like intended.
Where do I've the issue?I'm using a Klicky probe on my Voron Switchwire and I want to make a fast probe to get down to the surface, afterwards I want to do three slow and accurate probes.
Here's my config and homez file
Would be really grateful for some tips or hints!
config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3) ; executed by the firmware on start-up ; ; General preferences M111 S0 M575 P1 S1 B57600 ; enable support for PanelDue G21 G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Voron Switchwire" ; set printer name M669 K2 X-1:0:-1 Z-1:0:1 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 D3 V0 M569 P0.1 S0 D3 V0 ; physical drive 0.1 goes forwards M569 P0.2 S1 D3 V0 ; physical drive 0.2 goes forwards M569 P20.0 S1 D3 V0 ; physical drive 0.3 goes forwards M584 X0.0 Y0.2 Z0.1 E20.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 ; set steps per mm M92 E741.075 M566 X600.00 Y600.00 Z1000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z30000.00 E10000.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z5000.00 E30000.00 ; set max accelerations (mm/s^2) M906 X1200 Y1700 Z1200 E650 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y-8 Z0 S1 ; set axis minima M208 X250 Y210 Z205 S0 ; set axis maxima ; Axis compensation ;M556 S50 X0.10 ;M579 X1.001717 ; Endstops M574 X1 S4 ; configure sensorless endstop for low end on X M574 Z1 S2 ; configure sensorless endstop for high end on Z M574 Y2 S1 P"io5.in" ; configure active-high endstop for low end on Y via pin io5.in ; Z-Probe M558 K0 P5 C"^io6.in" H2 F4000 T9000 A1 S0.02 ; set Z probe type to unmodulated and the dive height + speeds M558 K1 P5 C"^io6.in" H2 F100 T9000 A3 S0.01 ; set Z probe for a second and more accurate G30 G31 P5 X0 Y25 ; set Z probe trigger value, offset and trigger height G31 Z6.20 ;Mesh grid M557 X15:231 Y25:210 P7:7 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3988 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R0.274 K0.241:0.000 D12.01 E1.35 S1.00 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"20.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S295 ; set temperature limit for heater 1 to 295C ; Fans M950 F0 C"20.out1" Q5000 ; create fan 0 on pin out3 and set its frequency M106 P0 C"Part cooling" ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"20.out2" Q5000 ; create fan 1 on pin out2 and set its frequency, and tacho output on out2.tach M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous M950 S0 C"out6" ; assign GPIO port 0 to heater3 on expansion connector, servo mode M280 P0 S154 T0 ; select first tool M150 X3 M98 P"/macros/neopixel/startup.g" ;; Global variables M98 P"/macros/startup/set_globals.g" ; After startup M98 P"/macros/startup.g" ;tone after config file was completely executed
homez.g
; Z-Home M564 H0 G91 ; relative mode G1 Z10 F2000 ; raise head 4mm to ensure it is above the Z probe trigger height M564 H1 M98 P"/macros/zprobe/loadclicky.g" ; call macro to load the Klicky probe M400 ; Wait for current moves to finish G90 ; back to absolute mode G1 H0 X125 F10000 ; put head over the x-axis centre of the bed, or wherever you want to probe G1 H0 Y90 F10000 ; put head over the y-axis centre of the bed, or wherever you want to probe ;M558 P5 C"^io6.in" H2 F4000 T9000 A1 S0.02 ; set Z probe type to unmodulated and the dive height + speeds G30 K0 ; lower head, stop when probe triggered and set Z to trigger height ;G4 P500 M400 G1 Z5 F1000 G30 K1 ;M558 P5 C"^io6.in" H2 F100 T9000 A3 S0.01 ; set Z probe for a second and more accurate G30 G91 G1 Z15 F1000 M98 P"/macros/zprobe/unloadclicky.g" ; call macro to unload the Klicky probe G90 G1 X0 Y0 F10000 M558 P5 C"^io6.in" H2 F500 T9000 A1 S0.01 ; set Z probe to standard back M564 S1
@The_Mechanic said in Change feed rate during Z homing:
M558 K1 P5 C"^io6.in" H2 F100 T9000 A3 S0.01 ; set Z probe for a second and more accurate G30Define just one probe, not two, like this:
M558 K0 P5 C"^io6.in" H2 F4000:100 T9000 A4 S0
F4000:100 tells it to probe at 4000mm/min for the first probe and 100mm/min for subsequent probes. A4 tell is to do at most 4 probes, and S0 tells it to always do all of them and average the results of the slow probes.
Thank you very much!
It works like you pointed out and how it wanted it to behave.But: one issue solved, another appeared...
When I'm doing a G29 before the print I'm having the same settings for those probings, which take nearly 4 times longer.Is the solution to use
M558 K0 P5 C"^io6.in" H2 F1000 T9000 A1 S0 before the G29? -
@The_Mechanic yes, you can make that change in bed.g at the beginning and then change it back at the end.
