Vin - sensor calibration
hello everybody , I wanted to understand if it is possible to calibrate the input voltage in some way, (I read only 8.7 volts on the video) I have already carefully checked all the input currents and on the board, they are correct, all at 12.2 v. can someone help me ?
@dindo59 if it's that far you then you have a wiring error and you are feeding 5V to the 3.3V rail. Correct your wiring before you cause permanent damage. If it's a Duet 2 then this is typically because the PanelDue ribbon cable is plugged into the wrong socket.
