RepRapFirmware configuration limits
Good Afternoon All!
I am reaching out for some help as i have made a HUGE oversight with my duet hardware that i purchased! I am needing 60 external outputs for a big pick and place machine we are retrofitting. I have the Duet 3MB6HC and 7 Duet 3 EB 3HC, Main and expansion boards. Have worked through allof the wiring but the feeders and am running into a big issue.
I was having issues when using the higher number Pins i had assigned. Started to look into the RepRapFirmware limitations and see where you can only use up to 32! Big mistake on my part. I looked into the limitations for the CAN bus using this many boards, no where did i come across the MAX OUTPUT limitation.
Looking for any ideas, suggestions, or a stern talking to about not doing my homework!!!
-Blake -
@BlakeG I can increase it in the next 3.5beta release. 56 outputs should certainly be possible, probably 64.
First and foremost, THANK YOU FOR THE SUPPORT!
Ill be looking for the release.
Thanks again!
