Error: in file macro line 41: G30: Z probe 0 not found
I have been running this machine for a while and then updated to the new beta 3.5 beta 2 and now I cant seem to get the homing to play nice. I was on 3.30 prior to the update and everything was working fine. Its driving me crazy and I cant seem to find the answers, Ive tried so many things but nothing seems to solve it. Thank you for your help!!!
Duet2 Wifi
Piezo Probe connected to zprobe pin, zprobe used as endstop
CoreXYM98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Pin 'zprobe.in' is not free
Error: Invalid Z probe index -
undefined csoup50 marked this topic as a question
M574 Z0 S1 P"!zprobe.in" ; configure Z-probe endstop for low end on Z
Remove that line from your config.g
Your homeall is confusing because it uses commands for a Z endstop, but then also calls G30 to use the probe.
What is your actual intention?
; Move Z down until the switch triggers G1 Z-280 F4000 H1 ;CC Added 1000 to F ; Absolute positioning G90 ; Tell the firmware where we are G92 Z-0.1 ; Uncomment the following line to lift the nozzle after probing G1 Z5 F900 H2 ;CC added ;M558 R1 H5 F2000 T6000 G30 ; Singe z Probe the bed at the current XY position, when trigged set the z coordinate to the probe trigger height
Your config isn't correct to use a z endstop, so just simplify that section to use only the probe with the G30.
@Phaedrux Ok I removed the M574 for the Z. What do you mean its confusing, Im not seeing what you are. Its me not you.
My intention is to lower Z, home x y and then home z with the probe.
The error you were getting was because you were trying to use the zprobe input pin in the endstop section, and then use it for the probe input itself.
Why lower Z the Z first before XY and then home Z again?
@Phaedrux Ok, I get what your saying. it seemed to be the only way to alleviate the errors. After removing the M574 I now get these errors. Error: Failed to enable endstops
4/14/2023, 8:10:11 PM G28
Error: Pin name needed for switch-type endstop on Z axisTo your second point, I want the build plate to drop slightly to reduce risk of dragging on the build plate before X and Y home.
You'll need to remove those G1 H1 Z moves to stop those errors.
To get some clearance for Z first that's much easier. Just add a G91 G1 H2 Z5 move before homing XY to raise the Z by 5mm.
@Phaedrux well it looks like you got me on the right track. I commented all those out as you said and added the command. Now im not getting the errors that I couldnt figure out! Thank you so much!!!
@csoup50 Im printing again, its been two days. Thank you again!
undefined csoup50 has marked this topic as solved
