syntax error in M593 stops print
Currently trying to see how IS works on my IDEX (see other thread), I did manually adjust IS settings during the print. At one time I erroneously passed in the frequency as a string
M593 P"mzv" F"40"
which yieldedError: M593: expected number after 'F'
. This is expected and fine. What I did not expect was the print to stop with the nozzle still heating sitting in place on the part.I would expect the error to be logged and the print to be continued as before, or the print be cancelled (not preferred) and running cancel.g
This is on a Duet 3 mini 5+ running 3.5b2.
@oliof thanks for reporting this. It will be fixed in RRF 3.5beta3 and 3.4.6.
