Height maps after hot end nozzle change
I change my hot ends frequently to change nozzle sizes. With the way the M2 is set up it is faster and safer to just switch hot ends.
So following the same process of setting the BLtouch trigger to Nozzle tip distance, updating M31 Zx.xx if it is slightly different than the previous hot end , the previous height map should still be accurate??? -
Yes, because the heightmap is a collection of offsets from the z0 point, not the trigger height of the probe itself.
@Phaedrux That was my assumption as well, just looking for verification. Been working through issues, trying to figure things out without asking
Is there a trick to using the search feature, I am really spoiled with Google or is that the trick, to use google rather than internal search? When I search for something specific using the forum search, it has a common term that is always returned finding everything but what I am looking for.. Like if searching for something that include a gcode I get every post with a config file that has that gcode.. -
The advanced forum search is worth looking at. You can limit the range in certain ways to keep from getting every post under the sun, but it also helps to have a more unique term. This is true of all keyword search. You can also use google to search the forum.
