protect config.g with password.
is it maybe possible to safe the config.g file with a keyword?
Best regards
Fabian
@FS-TOOLS said in Save config.g with keyword.:
with a keyword?
Can you elaborate on what you mean by this?
@Phaedrux
I mean, that only someone like an admin can change something in the system configurations -
@FS-TOOLS there's currently no password protection for the config etc
undefined Phaedrux moved this topic from Tuning and tweaking
What you could try is to use SBC mode and set the immutable flag on config.g on the linux side. Then you would need to be superuser to unset the flag before changes to config.g would be saved. I would not recommend this though, because its hard to debug when things go awry.
And even if config.g.would be locked down, users can change roughly every aspect of machine configuration dynamically via gcodes. So the next step would be to only allow "reasonable operator" and "admin" commands depending on who uses the machine -- and there is no facility for this. Its a can of worms.
