More colours please
DWC has light and dark themes. That's great, becasue my two machines are set differently and I never accidently start working at the wrong one.
Unfortunately / fortunately I now have three machines, and while configuring number 3 the number of times I've opened up config.g and started tampering and then thought - "hang on, that's not the setting I ... d'oh".
The problem is that I routinely have browser open with all three machines in different panes, it's easy (for me) to jump back to the wrong pane. Obviously it's a small thing, but I'd quite like the background of each mode to be not just white / black but rather a colour picker, so I can make my own choice.
As far as I am concerned the overlaying items (text, lines, etc) can still stay as the two current themes, but I imagine some people might like to fine-tune for aesthetics.
@achrn you can use btncmd to change the colour of the top bar https://plugins.duet3d.com/plugins/BtnCmd.html
@achrn It should be possible to add custom themes using a new DWC plugin, but to be fair extended theme support isn't a priority for me right now. If anyone is interested, check out https://vuetifyjs.com/en/features/theme/ and https://github.com/Duet3D/DuetWebControl/wiki/Third-Party-Plugins#creating-a-plugin.
@chrishamm Thanks for reply. I fully understand it's not going to be a priority, and mostly I should just be more careful, but I thought I'd log the request.
I'll look at the links, but I suspect it will be beyond me.
