Need Help CRtouch, update. Ender 3 Duet2 wifi
Got my system to home all with no issue. When running bed leveling I'm getting this error. I'm sure something in config is off.
Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
90 points probed, min error -0.608, max error 0.005, mean -0.318, deviation 0.144
Height map saved to file 0:/sys/heightmap.csv
2/1/2023, 11:24:10 AM Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
2/1/2023, 11:23:29 AM Warning: Skipping grid point X=200.0, Y=140.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=160.0 because Z probe cannot reach it
2/1/2023, 11:22:47 AM Warning: Skipping grid point X=200.0, Y=100.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=120.0 because Z probe cannot reach it
2/1/2023, 11:22:04 AM Warning: Skipping grid point X=200.0, Y=60.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=80.0 because Z probe cannot reach it
2/1/2023, 11:21:22 AM G29
Warning: Skipping grid point X=200.0, Y=20.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=40.0 because Z probe cannot reach it; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.15 on Tue Jan 31 2023 16:20:49 GMT-0800 (Pacific Standard Time); General preferences
M550 P"Ender3" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E136.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X400 Y400 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X235 Y235 Z250 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H2.5 F150 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X-48 Y-10 Z0.6 ; set Z probe trigger value, offset and trigger height
M557 X20:215 Y20:215 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
M106 P2 S1 H0:1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Please share your homing files and bed.g as well.
The offset warning means you may not be homing with the probe or loading a heightmap before homing.
The skipping point message just means that the probe can't physically reach points on the bed that you've asked it to probe. You can either ignore it, or adjust the M557 so that you're only asking it to probe points it can reach.
@Phaedrux (btw I test and adjusted G31 to Z1.180 trigger height)
Homeall.G
G91 ; relative positioning
G1 H2 Z2.5 F6000 ; lift Z relative to current position
G1 H1 X-245.5 Y-250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-245.5 Y-250 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X68 Y30 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z2.5 F100 ; lift Z relative to current position
;G90 ; absolute positioninghomex.g
G1 H1 X-245.5 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-245.5 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-2.5 F6000 ; lower Z again
G90 ; absolute positioninghomey.g
G1 H1 Y-250 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-250 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomez.g
G1 X68 Y30 F6000 ; go to first probe point
;G90 ; absolute positioning -
@Flynbrd said in Need Help CRtouch, update. Ender 3 Duet2 wifi:
90 points probed, min error -0.608, max error 0.005, mean -0.318, deviation 0.144At what point do you get that error?
Can you post your slicer start gcode?
Can you take a screenshot of your heightmap being displayed?
@Phaedrux
It's at the end of the run. I believe at the around the last probe point it flashes that error. Last time didn't generate a map.On the other note, you mention redefining my mesh. Looking at the errors the probe is having issues at 200x. Should I adjust the M557 to
Old
New
M557 X20:180 Y20:215 S20 ; define mesh grid -
Your mesh range should be your axis minima and maxima values added with the G31 X and Y values.
M208 X-5.5 Y-10
M208 X235 Y235
G31 P25 X-48 Y-10
M557 X20:215 Y20:215For X- the probe is on the left side, so it can reach all the way to the X minima. In other words, the probe can reach all the way to the left side of the bed. How far from the edge is up to you. Let's try 10mm.
M557 X10
For X+ the probe can only ever reach 48mm away from the right side. So X235 + (-48) = 187. Let's say 180.
M557 X10:180
For Y, same thing, it's on the front side of the nozzle and can reach all the way to the Y minima. So Y10
M557 Y10
For The Y max, it can only ever reach 10mm away from the edge. So Y235 + (-10) = 225.
M557 Y10:225
Putting it all together.
M557 X10:180 Y10:225 P5
I used P5 here instead of a S value. P has the firmware choose 5 equally spaced points between the min and max values giving a 5x5 grid.
S defines an exact spacing, which means you have to find a spacing that maximizes the available size yourself. Easier to just tell it how many points to use.
@Phaedrux
Thank you, it's up and running. My current mesh
With a glass bedOnly other issue I'm getting is a,
Directory 0:/macros/ not found
Not sure why, and I no macros in that folder. I wonder is somewhere in my configuration it's calling for a macro?
Do you have a macros folder in the root of the SD card?
No, there was no macros folder so I added one.
