Horrible print quality since upgrading
Yeah i'm not convinced I have the optimal route for the cable worked out yet. I've also noticed that the cable doesn't spin concentrically at the motor end. Not sure if this makes a difference or not or how I would fix this
https://photos.app.goo.gl/lTdTj8taKpn6q29Z2
The only other stepper I have kicking around is the one recommend for the titan
https://e3d-online.com/nema17-slimline-stepper-motor
but this is 0.9deg.
I agree with bot, if its possible to split the issue to isolate the issue(s). I know people on this forum have had good success with flexible drives but minimising the number of variables changing at once can help to find the problem quicker.
OK I switched back to my E3D titian extruder. Not good news. Constantly skipping and then my x axis started stuttering too!
https://photos.app.goo.gl/MGCq8oO2NUPvVVIT2
Here is my config for the titian
[[language]] ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M92 X80 Y80 Z400 E800 ; Set steps per mm M350 E16 I1 ; Configure microstepping with interpolation M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation M566 X300 Y300 Z24 E300 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z600 E300 ; Set maximum speeds (mm/min) M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
And here is my M112
M122
[[language]] === Diagnostics === Used output buffers: 3 of 32 (8 max) === Platform === RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0 Board ID: 08DGM-95BNL-MGPSJ-6J1F8-3SD6T-1KZ3W Static ram used: 21176 Dynamic ram used: 95960 Recycled dynamic ram: 1648 Stack ram used: 1304 current, 4840 maximum Never used ram: 7448 Last reset 00:02:17 ago, cause: software Last software reset reason: User, spinning module GCodes, available RAM 3232 bytes (slot 2) Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 18.9, current 19.4, max 20.6 Supply voltage: min 11.5, current 11.5, max 11.7, under voltage events: 0, over voltage events: 0 Driver 0: stalled standstill Driver 1: standstill Driver 2: stalled standstill Driver 3: stalled standstill Driver 4: standstill Date/time: 2017-11-10 23:38:33 Slowest main loop (seconds): 0.004425; fastest: 0.000034 === Move === MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heater = 0, chamber heater = -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. Network state is running WiFi module is connected to access point WiFi firmware version 1.19 WiFi MAC address 2c:3a:e8:0b:07:75 WiFi Vcc 3.02, reset reason Turned on by main processor WiFi flash size 4194304, free heap 38904 WiFi IP address 192.168.1.56 WiFi signal strength -37dBm HTTP sessions: 2 of 8 Socket states: 2 0 0 0 0 0 0 0 Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
Was that M122 report produced after a print, or before? The power supply voltage is a little low, and if it drops further when the heaters are on then you could be getting motor driver dropout due to the voltage going too low. OTOH if that M122 report is the first one you did after a print, then the minimum voltage is OK and there are no under-voltage events reported.
It was after, i'll boost it up a little
Have you got anywhere with solving the issues with the prints yet it would be interesting to know.
Doug
I had similar problems with my drive shaft extruder
it was like long waves
the solution for me was to make a more solid mount for the e3d/heatsink
i was using the normal e3d heatsink with a clamp at the top
but i guess the cable made it "swing a little" making this long waves
after changing to the aero heatsink (it has 2 screw holes , so it can be screwdown very tight)
this problem vent a waymay not be your problem but try to add some straps or something to test if that's your problem
You know it may have been that. I was using a piezo probe / mount. I did return the drive in the end as i'm afraid I had projects that needed to be completed by Christmas, so reinstalled my old extruder. I must say, the flex3drive creator was very helpful in supporting me but unfortunately I never got to the solution. I know other users who run a similar setup to me without issues. I can only assume it was a combination of the drive cable and my mount.
Just to update on this. I received the parts back to assess what might have been the cause given that this patterning was highly unusual from a Flex3Drive. Not seen before, anomaly!
Returned unit was fitted to a machine. Printed perfectly, Found deformation on plastics due to heavy over tightening of bolts. Was able to recreate the issue to confirm s thats good.. Steps taken to prevent recurrance.
