Combine Multiple IO's under one fan slider, Duet 6HC
I am wiring up multiple LED strips for my new Ratrig V-core 3.1 and one is already wired up under Out7, the other two strips I have wired up on Out9. Is there a way to control both of those outputs with one fan slider in DWC?
You might be able to define a dummy tool and then add all those LEDs as fans to that tool. Then the slider would control them all I think. Never tried it. Maybe there are better ways to do it, but that's the only way I can think of to get it into a slider in DWC.
@JamesM btncmd might let you create a slider
@jay_s_uk
I haven't played around with much in the way of plugins..just the input shaper so I guess I'll have to take a look.Honestly, a button would be find since I just turn my LED's on full or off.
@JamesM said in Combine Multiple IO's under one fan slider, Duet 6HC:
In that case just create a macro.
@Phaedrux
Well dang...I didn't even think of that. It always helps asking and someone else will think of something so simple.Thanks!
