G31 Z probe Temperature calibration
I have a heavily modified Prusa I3 Mk2.5s and am currently running a duet 2 wifi on it. I am extremely familiar with the duet firmware and g-codes however, I've hit a roadblock. The probe only works when the bed is cold since it is the Prusa "pinda". It has a thermister in the probe and I know that the G31 code allows the use of the S T and C parameters but I am unsure how to use them and could not find any documentation. Any help would be appriciated!
Thank you -
@Gregory it's described at https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status although the text isn't as clear as it could be.
