Only probe where the part will be printed
@Proschi78 said in Only probe where the part will be printed:
ke A5 in no
the A5 needs to be in the config.g where you configure the probe type
look for M558
https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type -
@danym21
I know that and I also have it in the config.g
but if I start a print and it only creates the mesh where the printed part is, then it only runs once in zM558 P1 C"io3.in" H5 A5 S0.009 F150 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z1.730; set Z probe trigger value, offset and trigger height M557 X30:330 Y-3:210 P9
@Proschi78
mhm, this makes no sense for me, do you have a M558 on some other positions? like in the the bed.g or config-override.g?I will test this when I have time for, I normaly use only one probe per point.
Just want to share the solution I made for this a couple of months ago (posted here)
as well.It works with PrusaSlicer/SuperSlicer, Cura and Ideamaker. Instructions are included as well.
https://github.com/MaikoHermans/RRF-PAM -
Has anyone managed to do it with simplify v5?
undefined jay_s_uk referenced this topic
undefined Phaedrux referenced this topic
undefined Phaedrux pinned this topic
undefined Phaedrux moved this topic from Tuning and tweaking
@Proschi78
I would like to know the same
