Cant connect DM542t to Duet2
i want to connect a Nema23 with external power supply and a dm542t as Driver to my Duet2 but the steppermotor spins only in one direction. If i test the Motor with forward and backward motion the motor turns forward and when it sould turn to the backward direction, it is also going forward but a little bit slower.
Can anyone help me with this problem?
If i connect a nema 17 direct to the Duet2 it works normally.
Maybe some grounding issue?
The wiring looks like this: -
@Nicogr you can't connect it like you have.
you'll need to use something like this https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board -
@jay_s_uk Thanks a lot for your reply, i will test it soon.
Do you Know if the Wiring with the expansion board is correct?wiring1.pdf
I cant move the motor
@Nicogr the second page looks correct.
Can you post your config? -
Thank you so much for your lightning fast response.
My config looks like this:
config (4).g
to Test the motor I run this macro but nothing happens; Test motors
M117 TEST E1
M584 X5
G91
G92 X0 Y0 Z0
;M201 Y1000
G1 H2 X50 F5000
G1 H2 X-50 7000
G1 H2 X50 F10000
G1 H2 X-50 2000
M584 X0 Y1 Z2 E3:5 U4 -
@Nicogr wheres you M569 setting timings etc?
i have set the M669 timing only on the Expansion Board Driver D5
M569 P5 S1 R0 T2.5:2.5:5:5
The Motor is spinning. I had to swap the ENA+ and ENA- cable
@Scara_Arm when using drivers with single-ended opto isolated inputs, it is better to use the alternate wiring scheme between the expansion breakout board and the external driver. See https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board#signalling-voltages.
