PT100 Daughterboard RTD2 problem
Hello!
I have a problem with new one PT100 Daughterboard. When I configue it using:
M305 P1 X200 ; Set PT100 sensor 1 M305 P2 X201 ; Set PT100 sensor 2
Duet returns ok, but on RTD2 channel temperature is 2000 C. When I replace it with other Daughterboard temperatures on both channels are ok.
Beside this I check both channels using 100 Ohm resistors - 2000 C on RTD2 so PT100 is ok. -
@lem when you connected the 100 ohm resistor to RTD2, did check that the two jumpers for that channel are in place on the daughter board? If so, please send an email to warranty@duet3d.com and include a link to this thread in the email.
