stampante delta kossel scale
Re: DWC 3.1.1
for delta kossel printer how to scale resize a print that has x y z different from the real design,
@luca-massimiliano You can use M579.
@chrishamm
M579 HOW TO CALCULATE THE NEW XY VALUES? AND Z WHAT VALUE? -
@luca-massimiliano do you have a STL or 3MF file for that print? If so then you can do the rescaling in the slicer.
so M579 X1 Y1 Z1 stays so I don't touch it? -
@luca-massimiliano yes scale on slicer and let the M579 default!
@weed2all
I HAVE NOT FOUND ANYTHING THAT RESIZES THE Z LA X LA Y WITH DIFFERENT SCALES, BUT ONLY THE POSSIBILITY OF SCALING THE TOTAL OBJECT. ON SLIC 3R IS IT POSSIBLE TO CLIMB EVERY SINGLE COORDINATE? MAYBE IT IS POSSIBLE WITH A G CODE? REAL DIMENSIONS X = Y = Z = 20 MM THE DELTA PRINTER Z = 16 X = 18 Y = 19
@dc42 NON HO TROVATO NULLA CHE RIDIMENSIONA LA Z LA X LAY CON SCALE DIVERSE, MA SOLO LA POSSIBILITA' DI RISCALDARE L'OGGETTO TOTALE. SU SLIC 3R È POSSIBILE SALIRE OGNI SINGOLA COORDINATA? FORSE E' POSSIBILE CON CODICE AG? DIMENSIONI REALI X = Y = Z = 20 MM LA STAMPANTE DELTA Z = 16 X = 18 Y = 19
@luca-massimiliano I CANNOT MODIFY THE SLICER INDEPENDENTLY X Y Z IT IS A DELTA I CAN MODIFY DIAGONAL ROD BUT THE DIAGONAL ROD IS A MEASURED VALUE OF SURE MAYBE THERE IS A WRONG VALUE THAT I CANNOT MEASURE PRECISELY FOR EXAMPLE OF THE EFFECTOR OFS
