Duet 2 Wifi (tried to software update and failed)
I tried to complete the firmware update and I reset the board and now I can't find it in BOSSA to add the new firmware I have googled around and can not find out how to fix this issue. I plug the board in and get the 5v, 3v and not the 12V because I am just using USB. I tried to use the Windows drivers but got files I don't get how to use. I have plunged in before without issues until this update.
Have you used the erase jumper or button on the Duet to clear the firmware yet?
If you already have a working firmware on the board you don't need to erase it like that.
Please try following these procedures #1 and if that doesn't work, proceed to #2.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-1
