[solved] Accessing DWC via WiFi on Google Nest WiFi Issue
I can't access DWC on any of my devices by typing in the Duet's IP address. I'm using a Google Nest WiFi to provide the WiFi network. I think the issue is that all my devices automatically connect to the 5ghz band while the Duet can only use the 2.4ghz band. On the router I was using previously I was able to access DWC from a device connected to the 5ghz band, but on Google Nest WiFi communication between devices on different bands doesn't seem to be working, or at least I can't get it to work. Band assignment is handled automatically on Google Nest WiFi, and I don't think I'm able to manually switch my computer to the 2.4ghz band.
Hoping someone might be able to help me out.
@jckray said in Accessing DWC via WiFi on Google Nest WiFi Issue:
With something like that, which is designed to be "user friendly", the options to configure it to your needs may be quite limited.
A quick check didn't turn up an actual manual.
@jckray Assuming you are running windows you should be able to tell your wifi card on your computer to only use a specific band.
Try:
win+x -> device manager
expand network adaptors and right click your wifi card & select properties. eg:
In the advance mode look for a property that allows you to constrain the card to a specific band (it will be different depending on your wifi card). Make a note of the current value before you change it. eg:
You may need to reboot for this to take effect. -
@mintytrebor Thanks for the suggestion. I gave this a go and I was able to get my computer connected to the 2.4ghz band, however, I was still unable to access DWC, so it must be something else causing the issue.
First off, I know nothing about Google's hardware.
It's possible that the WiFi connection you are using is a "Guest" connection. That type of connection is designed to allow a computer (or other device) to connect to the outside world (the Internet) but not allow a connection to another computer (or other device) that is already connected to your WiFi network.
Very embarrassing, but it appears I had a typo in my IP address and even though I thought I had double-checked, I somehow missed it. Everything is working just fine. Can access DWC from my computer while it's using 5ghz even though the duet is using 2.4ghz.
Feeling pretty stupid lol
