First cut success - with questions!
Maybe I've got to the bottom of this...
I've simulated several files from a specific Work XYZ, which is X27 Y198 and Z82. The maximum axis limits are X535 Y787 Z100.
I need to look at the Vectric software to see why, but I've compared a few gcode files produced by the Vectric software, and I've found this:
In both working and non-working files, there are four consistent lines of code at the start (excluding the headers) as follows:
G17 (Sets the XY plane for arc moves)
G21 (Sets the units to mm)
G90 (Sets to absolute positioning)Then the files differ.
In the files that can be simulated, this is the next line:
G0Z6.350 (Which moves the Z axes to a safe height, I guess)
...but in the files that can't be simulated, this is the next line:
G0Z20.320
I think this is the problem because if the Z Axis is already at 82mm when the Work XYZ is set, then trying to move the Z axis another 20.320mm will exceed the available Z axis movement of 100mm (82 + 20.32 = 102.32mm).
Does anyone agree, or am I talking out of my hat?
Thanks
@nightowl999 said in First cut success - with questions!:
Does anyone agree, or am I talking out of my hat?Yes, I think that is exactly what is happening.
Thank you, @dc42.
I was getting a bit tied up with this last night, but in the cold light of day - and after a good nights sleep! - a clear look at the problem certainly helps.
My thanks to @JoergS5 for pointing me towards the Z height, and everyone else who joined me on this journey.
Now all I have to do is find out why and prevent it from ruining my day again!
This post is deleted! -
