REVO Hemera Heater Faults
- list itemRevo Hemera direct drive
duet wifi 2 - firmware 3.4.0
Problem - multiple heater faults
extruder temp goes above set temp from slicer and keeps climbing until a heater fault occurs.Sometimes the temperature is correct and stats to print and during print a heater fault occurs. The 3D print surface indicates that the model is being printed much higher then what it should be.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 27 2022 07:58:07 GMT-0800 (Pacific Standard Time); General preferences
M550 P"EVO2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; phys4cal drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
;M92 X81.41 Y81.41 Z394.7 E400 ; set steps per mm
M92 X79.85 Y79.85 Z400.04 E392.47 ; set steps per mm
M566 X900.00 Y900.00 Z12 E300 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z3000.00 E1000.00 ; set maximum speeds (mm/min)
M201 X300 Y300 Z250 E1500 ; set accelerations (mm/s^2)
M906 X850 Y850 Z650 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
; Axis Limit
M208 X0 Y0 Z-10.0 S1 ; set axis minima
M208 X250 Y260 Z180 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z
;M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
;M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F500 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X7 Y-50 Z2.675 ; set Z probe trigger value, offset and trigger height
M557 X30:250 Y15:210 S20 ; define mesh grid;BLTouch Heater
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C0 R4700 ; configure sensor 0 as thermistor on pin bedtemp b4138
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M912 P0 S-12.6
T0 - list itemRevo Hemera direct drive
@blitzreg Sounds like a faulty HeaterCore, contact E3D for replacement.
@blitzreg Run a M303 T0 S300 to calibrate the heater and remember to configure the thermistor
@blitzreg
Can you send a picture of the graph?
I had a similar problem with 3 heaters with the same batch number.
R.G.
