Any SBC alternatives out there?
Anyone using any other SBCs that are not a raspberry Pi? If so, what’s been your experience with it?
@tlas yes. Anything that runs armbian and is an arm7v should be fine.
They run exactly the same as a pi -
@tlas you could search the forum for "Jetson Nano".
Just in case anyone still prefers Raspberry Pi SBCs, https://rpilocator.com/ will show you availability at various genuine resellers.
@TLAS @dc42 I can confirm a Jetson Nano works in conjunction with a 6HC. I do plan on releasing a full guide on getting a Jetson Nano to work, including the required pinconfigurations. Sadly I have some other projects with a higher priority at the moment. Maybe if there is considerable interest I can shuffle some things around.
@oliof
Thanks,
That site is great! But yeah, really shows how bad the supply problem is at the moment. -
@tlas we have a guide here for running DSF on armbian https://teamgloomy.github.io/dsf_on_armbian.html
