doc error on accelerometer page
I found an error on this page: https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer
In the wiring section, in the cable wiring table, Pin 9.
In the Duet Signal column, the text says "IO_3.OUT (Duet 3 Mini) or TWD0 (Maestro) or SPI.CS4", but there is no SPI.CS4 signal on the Temp Daughterboard connector on Duet3 MB6HC wiring diagram.In the configuration section of this page, the Duet3 MB6HC tab shows an M955 command that has "spi.cs3+spi.cs2" as the C parameter. So I think the table should have said SPI.CS2 instead of SPI.CS4.
@mikeabuilder on Duet 3 MB6HC it should be SPI.CS2 for INT1 and SPI.CS3 for CS. On Duet 2 and on Duet 3 MB6XD it should be SPI.CS3 and SPI.CS4 respectively.
@mikeabuilder The documentation page is now updated.
undefined droftarts marked this topic as a question
undefined droftarts has marked this topic as solved
