Duet 3 Mini + RPI4 + Touchscreen HDMI 7"
I've successfully set-up my new Duet3 mini with a Raspberry Pi 4 and all seemed to be working fine. I'm excited to install this control system into a new CNC router asap (I have a Duet2 wifi in my 3D printer which works beautifully).
This evening I've added the Waveform 7" HDMI touchscreen and I'm now getting the error, "Failed to connect to Duet3.home. Failed to connect to Duet, please check your connection (DCS is not started)".
I've searched the forums for similar issues but I haven't found anything yet. I've run the command, "sudo journalctl -u duetcontrolserver -e" which gave the following log.
Feb 15 19:00:51 duet3 systemd[1]: Starting Duet Control Server... Feb 15 19:00:52 duet3 DuetControlServer[8331]: Duet Control Server v3.3.0 Feb 15 19:00:52 duet3 DuetControlServer[8331]: Written by Christian Hammacher for Duet3D Feb 15 19:00:52 duet3 DuetControlServer[8331]: Licensed under the terms of the GNU Public License Version 3 Feb 15 19:00:53 duet3 DuetControlServer[8331]: [info] Settings loaded Feb 15 19:00:53 duet3 DuetControlServer[8331]: [info] Environment initialized Feb 15 19:00:53 duet3 DuetControlServer[8331]: [fatal] Could not connect to Duet (Error 16. Cannot put line into event mode.) Feb 15 19:00:53 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'. Feb 15 19:00:53 duet3 systemd[1]: Failed to start Duet Control Server. Feb 15 19:00:53 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart. Feb 15 19:00:53 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 692. Feb 15 19:00:53 duet3 systemd[1]: Stopped Duet Control Server. Feb 15 19:00:53 duet3 systemd[1]: Starting Duet Control Server... Feb 15 19:00:53 duet3 DuetControlServer[8369]: Duet Control Server v3.3.0 Feb 15 19:00:53 duet3 DuetControlServer[8369]: Written by Christian Hammacher for Duet3D Feb 15 19:00:54 duet3 DuetControlServer[8369]: Licensed under the terms of the GNU Public License Version 3 Feb 15 19:00:54 duet3 DuetControlServer[8369]: [info] Settings loaded
There is clearly an error in there ( "Could not connect to Duet (Error 16. Cannot put line into event mode.") but I don't know how to overcome it. Can anyone help me, please? Is there a code / pin conflict going on?
Any help appreciated!
Many thanks, Jason (UK)
How are you powering the Duet, the Pi and the touchscreen?
@greeno76 Did you have to change anything on the stock DuetPi image to get the touchscreen working (provided you're using that)? It sounds like there is a conflict with some peripheral device that prevents DSF from accessing a required GPIO pin, hence the error message. The output of
sudo gpioinfo
may provide extra information about potential programs interfering with it. -
Thanks both for kindly replying.
Regarding the power, the Pi4 has its own Raspberry Pi branded power supply. The 7" HDMI touchscreen is powered via USB to the Raspberry Pi.
The Duet3 mini is powered by it's own USB supply. Jumpers haven't been changed so should be in their default potision. The board is not yet connected to any motors or sensors. I've only had it running with the RPi for testing and basic config purposes so far.
The RPi also has a camera connected via the Camera interface running mpeg-streamer. This was running fine along with DCS before the HDMI screen was installed.
The RPi is running the 3.3 version software as you can see in the output above. It's the Duet IMG downloaded from the official repo. I haven't altered it, aside from running apt-get update/upgrade, installing mpeg-streamer and now sudo ./ LCD7-1024x600-show X, which I think appends the config.txt file with the HDMI info in the root filesystem.
FYI, Touchscreen is this one: Link to HDMI on Pi Hut. Here's the manual for the screen for reference.
7inch_HDMI_LCD_User_Manual_EN.pdfI've copied the output from sudo gpioinfo below. I'm not sure how to interpret it. Perhaps you can see some conflicted pins here?
pi@duet3:~ $ gpioinfo gpiochip0 - 58 lines: line 0: "ID_SDA" unused input active-high line 1: "ID_SCL" unused input active-high line 2: "SDA1" unused input active-high line 3: "SCL1" unused input active-high line 4: "GPIO_GCLK" unused input active-high line 5: "GPIO5" unused input active-high line 6: "GPIO6" unused input active-high line 7: "SPI_CE1_N" "spi0 CS1" output active-low [used] line 8: "SPI_CE0_N" "spi0 CS0" output active-low [used] line 9: "SPI_MISO" unused input active-high line 10: "SPI_MOSI" unused input active-high line 11: "SPI_SCLK" unused input active-high line 12: "GPIO12" unused input active-high line 13: "GPIO13" unused input active-high line 14: "TXD1" unused input active-high line 15: "RXD1" unused input active-high line 16: "GPIO16" unused input active-high line 17: "GPIO17" unused input active-high line 18: "GPIO18" unused input active-high line 19: "GPIO19" unused input active-high line 20: "GPIO20" unused input active-high line 21: "GPIO21" unused input active-high line 22: "GPIO22" unused input active-high line 23: "GPIO23" unused input active-high line 24: "GPIO24" unused input active-high line 25: "GPIO25" "ads7846_pendown" input active-high [used] line 26: "GPIO26" unused input active-high line 27: "GPIO27" unused input active-high line 28: "RGMII_MDIO" unused input active-high line 29: "RGMIO_MDC" unused input active-high line 30: "CTS0" unused input active-high line 31: "RTS0" unused input active-high line 32: "TXD0" unused input active-high line 33: "RXD0" unused input active-high line 34: "SD1_CLK" unused input active-high line 35: "SD1_CMD" unused input active-high line 36: "SD1_DATA0" unused input active-high line 37: "SD1_DATA1" unused input active-high line 38: "SD1_DATA2" unused input active-high line 39: "SD1_DATA3" unused input active-high line 40: "PWM0_MISO" unused input active-high line 41: "PWM1_MOSI" unused input active-high line 42: "STATUS_LED_G_CLK" "led0" output active-high [used] line 43: "SPIFLASH_CE_N" unused input active-high line 44: "SDA0" unused input active-high line 45: "SCL0" unused input active-high line 46: "RGMII_RXCLK" unused input active-high line 47: "RGMII_RXCTL" unused input active-high line 48: "RGMII_RXD0" unused input active-high line 49: "RGMII_RXD1" unused input active-high line 50: "RGMII_RXD2" unused input active-high line 51: "RGMII_RXD3" unused input active-high line 52: "RGMII_TXCLK" unused input active-high line 53: "RGMII_TXCTL" unused input active-high line 54: "RGMII_TXD0" unused input active-high line 55: "RGMII_TXD1" unused input active-high line 56: "RGMII_TXD2" unused input active-high line 57: "RGMII_TXD3" unused input active-high gpiochip1 - 8 lines: line 0: "BT_ON" unused output active-high line 1: "WL_ON" unused output active-high line 2: "PWR_LED_OFF" "led1" output active-low [used] line 3: "GLOBAL_RESET" unused output active-high line 4: "VDD_SD_IO_SEL" "vdd-sd-io" output active-high [used] line 5: "CAM_GPIO" unused output active-high line 6: "SD_PWR_ON" "sd_vcc_reg" output active-high [used] line 7: "SD_OC_N" unused input active-high
I'm a bit stuck. Is it worth me trying to reinstall the Duet software?
Once again, any help is hugely appreciated.
Thanks again,
Jason
@greeno76 said in Duet 3 Mini + RPI4 + Touchscreen HDMI 7":
The only thing I would try changing would be powering the display from it's own supply as well.
Thanks for your suggestion. I tried separate power supplies for all devices but unfortunately the issue still persisted.
Given that this is an as-yet unconnected system I've simply started from scratch and reinstalled the DuetPi img. The Duet3 mini board has successfully connected. I have since configured the HDMI touchscreen and Camera and the Duet3 is still connecting fine.
So, I'm not sure what I learned there!, Slightly concerning but hopefully it'll be fine if I don't meddle too much and I can go ahead and start wiring-up and configuring the CNC.
Many thanks for your replies.
Best wishes,
Jason
So you started with the DuetPi image that came on the SD card and reflashing the SD card with a fresh image solved it?
@phaedrux I should clarify in case its misleading for anyone in the future.
The original DuetPi image was downloaded from the official GitHub location as was the last install which appeared to solve my problem.
I think I must have bodged the HDMI screen installation tbh. I ran some install command but really it just needed to be configured in config.txt.
All seems to be working now. I've since upgraded to the 3.4 RC and I've successfully tested motion on the stepper motors.
Thanks again.
Jason
