Correction of heightmap is not really working
We are running the G30 in the
macro/z-offset Calibration; Z-setup Macro ; setup Z distance M300 S666 P666 ; beeo M291 S3 R"Test Z Probe Trigger Height" P"Press OK to continue, or CANCEL to abort" G28 ; home all G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute movements ; this complicated looking command computes the X and Y parameters needed to move the probe to the center of the bed G1 X{((move.axes[0].max + move.axes[0].min) / 2) - sensors.probes[0].offsets[0]}, Y{((move.axes[1].max + move.axes[1].min) / 2) - sensors.probes[0].offsets[1]}, F1800 M300 S1111 P666 ; beep M564 H1 S0 ; ignore axis limits M291 S2 R"Test Z Probe Trigger Height - Step 1" P"Place a paper sheet under the nozzle and raise the bed until slight friction can be noticed" Z1 ; G92 Z0 ; the nozzle should now be just touching the bed so set the logical Z position to match the physical Z position M300 S666 P666 ; beep M291 S2 R"Test Z Probe Trigger Height - Step 2" P"Please remove the paper sheet and wait for the bed-probing to begin" ; G1 Z5 F200 ; insure Z position will allow for probing G30 S-1 ; probe the bed and report the Z probe trigger height M564 S1 H1 ; respect axis limits M291 S2 R"Test Z Probe Trigger Height - Step 3" P"Copy the reported height value on the G-Code console and paste it into the config_probe.g file"
@fcwilt
We are running the z-offset calibration with the G30 in it
after we run the z probe calibration -
OK I see now.
A few things to mention:
For the other person I had shown how to use a variable to set the G31 Z Trigger Height setting. You have created the variable but I don't see that you are using it in config_probe.g.
Using the variable is optional. If you are not going to use it in config_probe.g then you can remove any other code referencing the variable. -
You mention using the formula to move to the center of the bed with Z0 added. But you show it after the F parameter without a comma separating from the F parameter. I don't believe it actual does anything without the comma. What was the intent of executing this command?
Anytime you change anything in your config_probe.g file you need to be sure it is executed before you attempt to use the new setting(s) in the file.
@fcwilt
So I don't switch out build plates, Just run a lot of the same material.
I know he wanted that extra part to change out plates.
So how do I need to change that. -
So I need change my config_probe.g Z setting back to
global.g_probe_z_trigger
like this; config_probe.g ; config the probe and call the other files.g M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1 M950 S0 C"duex.pwm5" G31 P25 X0 Y-30 Z{global.g_probe_z_trigger} ; set Z probe trigger value, offset and trigger height (larger value is closer)G31 P500 X0 Y-30 Z1.73
You don't need to use the variable I all. I don't use one. I just have the constant value for the Z Trigger Height parameter in my config_probe.g file.
If you want to use the variable then make the change you show to your config_probe.g file.
