Tool fan turning off during print
Hi all,
Finally recently decided to update to v3 of the firmware, and for the life of me I cannot figure out the following issue:
I have a simple setup of a single tool with an E3D v6 (tool fan connected to fan0 pins) with a single part cooling fan (connected on the fan1 pins).
If I'm starting a print, it seems to be using the tool fan like it was the part cooling fan (example, if I print with the part cooling fan off, when the print starts the tool fan turns off).
Here is my config:
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S285 ; set temperature limit for heater 1 to 285C; Fans
M106 P0 H1 T50 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S0 ; set fan 1 value. Thermostatic control is turned offUsing Cura, Extruder 1 is configured to use Fan Number 1
I realized that 45 minutes in a print last night, I'll spare you the damage details
@arakahn you have gone against our advice, which is to use fan 0 as the print cooling fan in single-nozzle setups and use fan 1 as the thermostatic hot end fan.
What fan control commands did Cura write into the GCode file?
Oups! I must've missed that advice Apologies
Here is what Cura is generating (still runing v4.6 as latest versions keeps crashing on me).
M107 P1
I'll invert the pins see if it resolves it
Well problem solved.
Thank you @dc42 , that was a prime case of an error code18.
Lesson of the day kids; read the documentation properly and ALWAY follow the devs advice.
