X motors are engaging when I move my Z motors, and vice versa
I have a Creality CR10 v2. I pulled all the connections from the original controller nd display. I am now connected to my Duet2 ethernet and Due Panel 7.When I move my Z motors my X motors move in the same direction as well. So if I move my Z motors 50mm my x motors move 50mm. All three motors are being commanded whether I tell the X or the Z motors to move. Any suggetsions?
Check you config for M669?
It sounds a bit like the Duet is configured for different mechanical system - something like a Delta or CoreXY printer rather than cartesian type?
You were correct. I had it configured as a XZ
