RRF 3.3.0 - printer does not know he is in pause
Hello dear Duet3d community,
I came across a bug I thought was fully fixed.
How to reproduce:
printer prints
-> filament runs out and FW runs pause.g
-> filament unloads (see conditional gcode in pause.g below)
-> printer forgets it's state and I can't resume the print afterwards
In an older FW version the printer directly resumed printing when messages were in pause.g.
This time the printer just forgets it's state.Workaround would be to delete the messages but I don't think it's an intended behaviour?
Config and macro files:
config.g for Duet 3 Mini
; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 P"Walross" ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet M575 P1 S1 B57600 ; Panel Due ; Printer geometry M669 K1 ; Select CoreXY mode M208 X0:290 Y-3:290 Z-0.4:260 ; Axis Limits M564 H0 ; allow unhomed movement ;------- drives from top--------------------------------------------------- ; B -------+------ A ; | P.02 | P.03 | ; -------+------- Z-Drives ; | P0.1 | P0.4 | ; -------+------- ; Front ; Drive Mappings M569 P0.0 S1 V0 ; Drive 0: E Axis M569 P0.1 S1 V0 ; Drive 1: Z-LeftFront Axis M569 P0.2 S0 V0 ; Drive 2: Z-LeftRear Axis M569 P0.3 S1 V0 ; Drive 3: Z-RightRear Axis M569 P0.4 S0 V0 ; Drive 4: Z-RightFront Axis M569 P0.5 S1 V0 ; Drive 5: Expansion: B motor (X-axis) M569 P0.6 S0 V0 ; Drive 6: Expansion: A motor (Y-axis) ; Motor remapping for dual Z and axis Limits M584 X5 Y6 Z1:2:3:4 E0 ; Motor mapping M671 X-60:-60:360:360 Y-10:370:370:-10 S20 ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front ; Microstepping and Speed M350 X32 Y32 E16 Z16 I1 ; Configure microstepping with interpolation M92 X160.00 Y160.00 Z400.00 E400.00 ; Set steps per mm 1.8 motors ; Speeds, Acceleration and Jerk M566 X300.00 Y300.00 Z25.00 E5000 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z900.00 E1200.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z1000.00 E6000.00 ; Set accelerations (mm/s^2) ; Motor currents M906 X1200.00 Y1200.00 Z1200.00 E600.00 I55 ; Set motor currents (mA) and motor idle factor in percent M84 S600 ; Set idle timeout ; Endstops for each Axis M574 X2 S1 P"io1.in" ; Set X endstop controlled by switch M574 Y2 S1 P"io2.in" ; Set Y endstop controlled by switch ;M574 Z1 S2 ; Set endstops controlled by probe "OLD" VINDA M574 Z1 S1 P"io6.in" ; Z endstop switch ; Stallgaurd Sensitivy (maybe use to pause print after crash) M915 X S2 F0 H200 R0 ; Set X axis Sensitivity 1.8 motors M915 Y S2 F0 H200 R0 ; Set y axis Sensitivity 1.8 motors ; Input Shaper and Accelerometer ;M955 P0 C"io4.out+io4.in" ;M593 P"zvd" F42.54 S0.1 M593 P"daa" F42.54 ; Z-Probe Super PINDA M558 P5 C"io3.in" I1 H2.5 F250 T12000 A500 S0.003 ; VINDA C"^io3.in" for PINDA... Vinda C"io3.in" ?? ; Mesh Grid M557 X5:280 Y30:250 P5 ; ; Z Probe Offset (Probe behind Afterburner) G31 P1000 X0 Y25 Z1.367 ; Heatbed Heaters and Thermistor Bed M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; Heatbed Thermistor M950 H0 C"out0" T0 Q10 ; Creates Bed Heater (SSR) M307 H0 B0 R0.821 C62.7 D6.19 S1.00 ; PID since 3.2 M140 H0 ; Bed uses Heater 0 M143 H0 S116 ; Set temperature limit for heater 0 to 115C Bed ; HotEnd Heaters and Thermistor HotEnd M308 S1 P"temp1" Y"thermistor" T100000 B3950 C0 ; define E0 temperature sensor M950 H1 C"out1" T1 Q100 ; Create HotEnd Heater M307 H1 BO R2.943 C117.2:87.3 D5.08 S1.00 V24.4 M143 H1 S295 ; Set temperature limit for heater 1 to 285C HotEnd M302 S185 R185 ; min extrusion (cold extrusion) temp ; Fans Hotend + Part M950 F3 C"out5" Q100 ; Creates HOTEND Fan M106 P3 T65 L0.8 X0.8 H1 ; HOTEND Fan Settings M950 F0 C"out6" Q100 ; Creates PARTS COOLING FAN M106 P0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN ; Fans Electronic compartment & Exhaust M950 F1 C"out3" Q100 ; Creates Case Fan 1 M106 P1 T40 L130 X130 H0 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed M950 F2 C"out4" Q100 ; Creates Case Fan 2 M106 P2 T40 L130 X130 H0 ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed ;M950 F5 C"out2" Q100 ; Creates Exhaust Fan ;M106 P5 T105 X50 H0 ; Exhaust fan ; Filament Runout sensor ;M950 J4 C"io5.in" ; Input 4 filament sensor ;M581 P4 T2 S1 R1 ; Filament Sensor P4 triggers inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1) M591 D0 P1 C"io5.in" S1 ; Filament Sensor ; Tools M563 P0 D0 H1 F0 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
pause.g
; pause.g ; called when a print from SD card is paused ; M83 ; relative extruder moves G1 E-3 F3000 ; retract 3mm of filament G91 ; Relative Positioning G1 Z10 F360; Raise Z G90 ; Absolute Values G1 X10 Y0 F12000 ; Parking Position if sensors.filamentMonitors[0].status == "noFilament" M98 P"0:/macros/Unload Filament"
Unlooad filament script:
T0 ; Activate Hotend M291 P"Retracting filament..." R"Unloading sequence" T5 ; Display another message ;Anti Blob Unloading Sequence G1 E5 F1800 G1 E-6 F1800 G4 S4 ; wait 4 seconds G1 E8 F1800 G1 E-120 F1200 ; Retract M291 P"Press OK" R"Unloading complete?" S2 ; Display new message
@argo I have added this to my list to look at.
@argo have you tested the behaviour in RRF 3.4.0beta7 ?
I just did. The M291 messages do not cause the issue anymore.
@argo thanks. Thanks to your example I found another bug, which is that if a macro contains a non-blocking M291, some motion and then a blocking M291, with no M400 or G4 between them, then the blocking M291 can appear ahead of the non-blocking one and then you can't cancel the blocking one. This is fixed in the forthcoming 3.4.0rc1. Please try 3.4.0rc1 when that is released.
