Driver install for USB
When I installed my first board I sailed right thru all this and now its being a real pain in the butt, with this board any ideas. Thank you
Which bit are you stuck on?
Sending M552 S1 and this is the message I get wifi reported error no known networks found, wifi module is idle. With the first board I had no trouble with this at all
Have you loaded up your WiFi access point details with the M587 command as DC linked to above?
M587 S"your-network-ssid" P"your-network-password" remember this is case sensitive so will need to be put in using a text editor or dumb terminal such as yat or possibly even hyperterminal will do it or put the command into a macro but I suspet you will need to use a terminal program as you wont be able to load a macro unless you move the SD Card to the PC
When I send 587 S I get bad parameter in 587 command. When I did all this with my first board everything worked like it was suppose. I know right now I have 1.19.1 driver. I have no idea what firmware came with the board, but something is not right. I am able to take the sd card out and put in my computer. I am getting really close to going back to my ramps board a 3 color diamond
What is the exact M587 command you are running that it is telling you has a bad parameter? You can obfuscate the password when replying.
M587 or M587p remembered networks TNCAP2FCC19 or M587S bad paramter in M587S
