M669 S and T values
I have a few questions regarding the M669 S and T parameters which I’d be grateful for any help with:
What are the minimum allowable values for the S and T parameters?
If I set S0.1 does this mean I can be confident my CNC will pause within 0.1 seconds?
Similarly, if I set T0.1, does this mean the CNC will pause within 0.1mm?
@droftarts Thanks, Ian. Will have a go this weekend…
@droftarts It appears that M669 doesn’t report the S and T values? This is my console output:
26/11/2021, 21:11:46: Connected to 192.168.0.9 26/11/2021, 21:12:19: M669 S0.001 26/11/2021, 21:12:32: M669: Kinematics is Cartesian, matrix: 1.00 0 0 0 1.00 0 0 0 1.00 26/11/2021, 21:12:46: M669 S1.0 26/11/2021, 21:12:52: M669: Kinematics is Cartesian, matrix: 1.00 0 0 0 1.00 0 0 0 1.00 26/11/2021, 21:14:17: M669 S1.0 T1.0 26/11/2021, 21:14:27: M669: Kinematics is Cartesian, matrix: 1.00 0 0 0 1.00 0 0 0 1.00
@cjm that's correct. I've already raised this
@jay_s_uk the latest builds do report the S and T values, but the latest released beta doesn't.
@dc42 Thanks for clarifying the M669 reporting of S and T.
There has been some discussion of setting S and T to small values, so that the time delay and distance moved after a pause command can be reduced.
I wondered whether you be able to explain a little more about any trade offs as S and T are reduced ?
