Corner LEDs not working
I just noticed that the LEDs that are at the points aren't lighting up. the little green one for the probe and the orange for the heater do. everything else seems to be working, Hot end fan is cooling.
That sounds odd, it would mean that you have 2 separate hardware faults on your effector.
Just to clarify since the diagram appears to show the prototype the black is for the hot end and white is for the print cooling. What and how can I check things out to help diagnose this?
Check you have the heater wires connected the right way round. The orange LED won't Illuminate if you swap the + and - connections.
The LEDs are intended to be viewed from the top of the effector.
The orange heater led comes on. As a general rule the heater and thermistor aren't polarized to my knowledge. The only ones that do not come on are the 3 that should be lighting up the print.
I'm sorry, I misread your post. The three white LEDs should be on whenever the heatsink fan is on. If the heatsink fan runs but the LEDs do not light up then there are two possibilities:
1. You have the hot end heatsink fan + and - terminals on the 6-way connector swapped, and you also have the + and - terminals of the 2-pin hot end heatsink fan connector swapped. Check that the red fan wire goes to the pin labelled + on the effector PCB.
2. One of the LEDs (or possibly the series resistor) is faulty or has been damaged.
Has to be option 2 then, all the power and heater wires check out
check each led to ground going around starting closest to the main plug till I find the break sound like a plan? I have a hot air soldering station and a syringe of solder paste. I'm untested on it, but it looks pretty straight forward.
Look at the LEDs and their soldering first to see if you can spot a problem. If not, try measuring the voltage across each LED when they should be on. If you find one with 12V or 24V across it, that one is open circuit.
since I was taking things apart on another project I took the time to measure the voltage at the LEDs. I have them reading 0.6 1.1 and 1.5
I'm guessing that those readings are between the anode of each LED and the negative supply. Is that correct? What supply voltage are you using? The LEDs are designed for a 12V or 24V supply to the hot end fan, depending on the position of the jumper. 5V will not be enough to light them.
24v supply, I read to the left and right of each LED, I'll see if I can find my alligator clips and read between a fan negative and the LEDS, and update.
all are @ 1.5v or less
I suspect there is a fault in your effector. If you look at the schematic at https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf you will see that the three LEDs and resistors R8 and R9 are all connected in series across the hot end fan input terminals. So if the anode of D1 is less than 1.5V relative to H_Fan_- then that suggests to me that R8 or R9 is open circuit, or not soldered properly.
okay, I will look after this print finishes
dc42
I have same problem. its my fault. can your give me specs on LED so I can order replacement. -
The part number for the white LEDs is CLM3C-WKW-CWBYA153.
and now this, can't get to printing temp even though it has been working fine other than the LEDs, could the hotend heating up soften the solder enough to do this?
The hot end, no. Bad connection, yes.
It looks to me that the green plastic housing has slid down, but the metal pins are still exactly where they should be. That should not be a problem, except that if you need to remove the heater wires you will probably find it easier if you push the green plastic part up so that it touches the PCB again.
sry so late getting back, real life stuff keeps getting in the way of play time, and it comes first.
I have 2.1-2.8 from the fan+ when its running to each LED, but none are lighting up
also have voltage at D8 and D9
