Can the Duet3 mini5+ be used as a Duet3 expansion over CAN?
I thought I heard something along these lines in the past but can't find any references about this.
Could a Duet3mini5+ be used as an expansion to another Duet3 board? Either a 6mbhc or mini5+.
Conceptually it should behave like any other expansion, but is there a firmware available to support this?
If this were possible, could it be any Duet3 to Duet3? There's no reason a 6mbhc couldn't be an expansion for another 6mbhc (or any combination thereof)
@pfn we are working on this and it is partly supported at present. When used as an expansion board, a Duet 3 Mini or MB6HC can support most motor functions, most types of temperature sensor, GpOut and GpIn ports. It cannot yet support heaters, fans or filament monitors.
See https://duet3d.dozuki.com/Wiki/M954 for how to put a board in expansion board mode.
@dc42 great information. Thank you!
@pfn i kinda know why you ask
I'm doing exactly the sameAlready reserved the space for it
